norburybrook wrote: ↑Thu Nov 14, 2019 3:43 pm
hmm a few cracking intermittent issues to sort out today....the OT secondaries are crackling when chopsticked.....is that normal?
Edit: its quite bad now, loud enough to maybe damage the speaker
 pressing on the OT Ht and secondaries (4-8-16) wires is where the noise is coming from. The connections at the switch are fine though and individually they're silent when chop sticked, pressing on the twisted together wires makes the noise come and go. Its not volume dependant so I presume nothing to do with the pre amp stages.
this is a new one on me. It was on all day on fire up day no problem.
Anyone?
M
Sorted....
it turned out to be plate wire from the PI that was running underneath the OT wires so prodding them was causing the hidden wire to crackle. Re-flowed the joint at the plate resistor and shortened the wire and its lovely and quiet again.
I threw my NUX verb/delay pedal in the loop today. Works great as it has a +4 setting so will take line level/hot signals if i so wish. Interesting that the NUX is exactly the same size/layout as my Strymon flint.
Also with something in the loop i can hear the effect of the bright cap. I might actually remove the bright cap from the loop and put a separate bright cap on the clean master, that will make sure the OD never gets to bright which it could with the loop.
More tweaking
It's funny, I plugged my second gen amp in to A/B against the hybrid new build and not having used it for a while as I've been using my Princeton and Tweedle dee, I thought it sounded awful!! LOL Bizzare...your ears/mind change depending where you 're at
 . Ive got 2 demos using that amp that sound fantastic, yet today it sounds horrible! go figure, probably the guitar I'm using it with, these amps are incredibly picky and temperamental with guitar choice i find.
I think I'm going to end up with a one pickup telecaster and or a Les paul Junior and ONE AMPLIFIER......
M
M
