Bending large chassis without a traditional brake.
Guy77
Post by Guy77 »
I had a 19 in long chassis that I had to bend and I did not have a traditional floor standing brake to bend it in. I found these clamping jaws at my local hardware store. they are called "Vise mount bending brakes". It cost me $36.
I was very impressed at how well it worked out! I was able to convert a chassis that was made for a head build into a chassis that would hang down in a traditional tweed style cabinet I had built. The chassis was 8 in deep and I needed it to be 5.5 in deep . I was able to easily resize it with the Vise mount brake!
Even though the jaws are only 6in wide and the chassis was 19in wide, I would just bend it a little then slide the chassis and keep bending until all 19 in was bent a little, then I would make another pass and bend it more until I had a full 90 degree bend. It took me about 3-4 passes to complete it.
Cheers
Guy
joeboo88
Re: Bending large chassis without a traditional brake.
Post by joeboo88 »
thanks Guy!
I was just wondering the other day how to accomplish what you just posted.
this will help alot
nice cabinet too
Unusual to find those bending brakes like that but that's what box breaks use.
Nice job.
TUBEDUDE
Post by TUBEDUDE »
Used to use 2" angle iron. Clamp 2 back to back with the sheet between them on a table edge. Then with a rubber mallet and a section of 2x4, hammer the crap out of it until it submits or you do. 😉
Guy77
Post by Guy77 »
joeboo88 wrote: Thu Sep 12, 2019 3:17 pm thanks Guy!
this will help alot
nice cabinet too
Thanks Joe. Glad this was helpful ! One thing I would do over again was to mark a darker line to follow where I needed to bend. Other thing I noted was that these things are fairly heavy and a little sharp and if they fall off the vise be careful they don't land on your toes !
Cheers
Guy
