"ghost" amplification...
sbirkenstock
Post by sbirkenstock »
Hi Everybody,
I was working on a Fender BF style amp today.
I was feeding a 1V peak to peak sine wave into the input.
When I turned the amps volume to 0, the sine was still well audible.
I experienced something like this before in other (Fender) amps, where some signal is audible despite the volume set to 0.
So I checked with my oszilloscope.
No signal at the mixing resistors, no signal at the input of the phase inverter.
But the signal was on both outputs of the phase inverter....
I also checked that the power supply was stable.
The amp works very fine though if you use it with a guitar!
Any hint?
Stephan
sluckey
Re: "ghost" amplification...
Post by sluckey »
1Vpp is too much. Turn it down to about 0.1Vpp or 0.2Vpp.
Littlewyan
Post by Littlewyan »
Isn't this normally due to a poor grounding scheme? Old Marshall 1987 or 1959s do this on the High Treble channel
An unbypassed (or poorly bypassed), shared cathode resistor will pass signal to the other triode.
