6L6GC
RightLurker
6L6GC
Post by RightLurker »
A friend recently dropped off a Fender Bandmaster Reverb head for a checkup. All of the tubes are RCAs. The power tubes are 6L6GCs, both RCA, but one is taller than the other. The taller of the two has a small "FK" printed on the bottle; the shorter one has a small "CT." The internal construction appears similar, if not identical. Can anyone educate me on the differences between the two tubes? Thanks in advance.
sluckey
Re: 6L6GC
Post by sluckey »
I's say about a half inch. :mrgreen:
pompeiisneaks
Site Admin
Re: 6L6GC
Post by pompeiisneaks »
aside from sluckey's sarcasm ;D, I think the internal components look identical in size etc, so maybe they used up some glass from older larger ones on some of the newer internals. Just a guess. I know over time they found ways of making them slightly smaller etc. and may have just been using up the old glass with the new internal sized components.
Just an educated guess.
sluckey
Re: 6L6GC
Post by sluckey »
FK and CT were the initials of the glass blowers. FK worked the mid shift and was known to blow a bit harder. His glass became known as 6L6GC. CT's short stuff was split off and became known as 5881s and awarded a huge government contract. I learnt that from Alfred A. Newman. :mrgreen:
Re: 6L6GC
Thus, the origin of the term, "blowhard."
Ten Over
Re: 6L6GC
Post by Ten Over »
sluckey wrote: Tue Aug 06, 2019 10:43 pm I learnt that from Alfred A. Newman.
Any relation to Alfred E. Newman?
Ten Over
Re: 6L6GC
Post by Ten Over »
xtian wrote: Tue Aug 06, 2019 11:21 pm Thus, the origin of the term, "blowhard."
It just goes to show that you can learn something new everyday, no matter how old you are. I always thought that term came from a Geisha Girl's mangled English.
Re: 6L6GC
Same tube from different production runs before and after a height spec change. Most likely a cost-cutting move.
Re: 6L6GC
Post by Stevem »
The bigger tube is just a later blackplate version, the internals are the same .
The smaller tube likely has a tighter vacuum level
sluckey
Re: 6L6GC
Post by sluckey »
Ten Over wrote: Wed Aug 07, 2019 4:02 am
Yes. His twin sister. I get'em mixed up all the time. :lol:
