Bias Voltage Source with GZ34
dorrisant
Post by dorrisant »
When using a GZ34 rectifier, is it possible to tap the AC going to pin 4 or 6 for a bias supply? Am I just pissing up a rope trying to do so? Space is limited and the PT didn't have a bias tap. I was going to do the usual Marshall trick but getting no bias DC. I also tried tapping the HT with a class X cap and then onto the bias circuit a la Marshall as well. Neither seems to generate any DC voltage at all.
I think I could use a tiny toroidal PT to get the bias AC, although that will be an exercise in cramming 10 lbs of s#@* in a 5 lb sack. I can do it that way but want to verify that I have painted myself into this corner before I try ordering any more parts.
If there is any reading material available that explains what the rules are surrounding this situation, please let me know. I have Slukey's Amp Scrapbook (p6), but I'm looking for a little more depth into the the reasons why.
Thanks in advance!!
Re: Bias Voltage Source with GZ34
I don't know why the "Typical Marshall" circuit wouldn't work. You have a FW rectifier set-up with a grounded CT, right?
pompeiisneaks
Site Admin
Post by pompeiisneaks »
That's sluckey's amp scrapbook, he could likely give you an exact answer if you give an explanation and details of the transformer. You can almost always pull a feed of the secondary ac windings and peel off into a half wave rectifier to get the negative bias.
sluckey
Post by sluckey »
That typical Marshall circuit is the one to use with a GZ34. It needs no explaining. It's very simple. If it doesn't work for you then you have a wiring error or bad diode or caps.
EDIT... BTW, you need to be looking at page 5. There is nothing on page 6 that applies to your situation.
dorrisant
Post by dorrisant »
I swapped the tap over to pin 4 of the rectifier socket rather than 6, tried it again. All good now. Had to have been a connection issue.
Thanks for the direction to all.
Advice from Dr Z to me last fall was dump the JJ GZ34's and use Sovtek 5AR4's and that was a good tip.
Just burnt up a new JJ GZ34 in a new JTM45 KT66 build while the owner was on a gig. Oh how embarrassing for me, he was a good sport about it.
pdf64
Post by pdf64 »
Perhaps the JJ would have had a long operational life if it hadn’t been used in an unfortunate hot switching standby arrangement (for reasons unknown DrZ amps use that too)?
It seems unfair to give JJ a bad rep because they break if thrown at a brick wall.
Throw them all at that brick wall :lol:
Most of my JJ GZ34 were not hot switched they failed while the amp was being played.
Replace with Sovtek and the amps are still operating at gigs.
I did check all grounds and solder joints as well as power tube bias etc. in these amps. I wasn't just merely blaming JJ tubes without full inspection of the amps.
In the last two weeks there were 3 fails.
didit
Post by didit »
As I reported in another thread a while ago, after a few frustrating capricious failures I too have given up on JJ for GZ34. Too fragile compared with available alternatives.
Best .. Ian
pdf64
Post by pdf64 »
:oops: sorry for jumping to the wrong conclusion, the mention of JTM45, DrZ and rectifier tube failure set the ‘hot switching’ bee in my bonnet a buzzing.
Colossal
Post by Colossal »
I have had good results with the Sovtek GZ34/5A94. Quite similar sound and feel to a Mullard too at 1/10th the cost. The old Mullards are the standard though.
