DIN jack
DIN jack
Hello all:
Would anyone be able to point me towards a new production part number for this type of DIN jack and its mate? I am working on a #102 build and would like to get the male and female DIN and footswitch connections close.
Thanks, in advance, for any leads
				Bombacaototal
Re: DIN jack
I got this mouser part #: 161-0005-E Kobiconn DIN ConnecorColossal wrote: ↑Wed May 29, 2019 1:36 pm Hello all:
TARIC: 8536699099
Re: DIN jack
Hi Rafael,
Thank you for the reply and help. That Kobiconn part is what I am currently using as well. I was looking for the raised, female version which is used on 102 and its matching male connector. I think the male connector on the footswitch lead may be locking?
- norburybrook
Re: DIN jack
Didn't #102 use the switchcraft XLR?  That's what is on mine and what the chassis was made for.
Any 5 pin DIN will work . They're a nice tight fit so you don't actually need locking if you don't want to.
MC
MC
						Re: DIN jack
I used the switchcraft 61HA5FX for female and the switchcraft 12CL5MX for male
						Re: DIN jack
Ah Marcus, right again.  I'm way out over my skiis.  I should have looked at the back of the amp!  I should have also clarified that I am using Taylor's ODS chassis which is cut for the Kobiconn recessed female connector that Rafael posted. I thought I might upgrade to a more historically correct jack, but it seems that should be XLR, not DIN at all.
						- norburybrook
Re: DIN jack
If you're using Taylor's chassis then just get your self a 5 pin Din . It's up to you there's all kinds to choose from and I think they all fit the hole.
If you use a 'midi' socket then I think a regular midi cable will work. That means you can always get a cable from any music store if it breaks.
Or you can hard wire at the footswitch end and just have a male connector on the amp end.
M
p.s. the switchcraft XLR cost me about $50!!!! so I'd go with the DIN every time of possible....they're about $5 max
M
Re: DIN jack
I've already got the recessed 5-pin DIN in there now, so problem solved. I have matched/mated connectors for the footswitch lead and some Belden five conductor.
The amp doesn't have to be a dead-on clone, but was just looking to pay homage where I can and stay true to the original as is practical. I'm far more concerned about these things than the customer.
- norburybrook
Re: DIN jack
Glad it's sorted Dave. I use 'Start Quad' cable for my footswitches. I use Van Damme as it's great cable but any will do, Belden, Mogami etc You have two pairs and the shield which is perfect for the 5 pins  It's also 'pro' cable so designed for life on the road and all that entails
M
						M
Re: DIN jack
Yes I used the same pair. Excellent connectors!
https://www.mouser.co.uk/ProductDetail/ ... 0hkA%3D%3D
https://www.mouser.co.uk/ProductDetail/ ... 8aXQ%3D%3D
- norburybrook
