xtian wrote: ↑Fri Feb 22, 2019 5:25 pm
No, there will be a small gap only, created by raising the chassis toward the top as you tighten the screws.
Are you sure there is just a small gap and not a 3/4 inch gap between the bottom of the chassis and the top of the horizontal support? Maybe I am just missing something really obvious but that doesn't add up for me.
I'm assuming the cross bar is 3/4 inch wide.
The first pic shows that the channel that you routed for the crossbar is *above* the horizontal support piece. So if the bottom of the chassis, when screwed in, is above the cross bar then there has to be 3/4 inch between the bottom of the chassis and the top of the horizontal support piece doesn't there?
Later in the thread there is a pic of the back of the amp that seems to confirm the 3/4 inch gap that I would expect but the angle makes it hard to tell for sure.
The reason this detail is important to me is because I was thinking that the *top* of the routed channel that the cross bar goes in should be even with the *top* of the horizontal support. That way, when the chassis is slid in, there is only like a 1/8 or 1/16 of and inch gap between the top of the chassis and the top of the cabinet.
