It started with a chassis from a Behringer mic preamp that I stripped. It's two rack units high, quite a big box.
I thought I would limit myself to the confines of that box and get everything to fit inside, including the tubes. So I started to think "micro"
I'm also limited to a total of six pots. Lots of switches, but I'll save those for later.
I've long been fascinated by the preamp in the Marshall 200 a.k.a "The Pig". So that's one channel and the other is similar to a brownface Deluxe.
I have transformers in mind, and will probably have B+ at around 300V. As I'm also using this as an opportunity to learn how to make schematics using software, I've only managed to draw the audio circuit so far
Thought I'd upload it anyway for possible comments and critical evaluation...
