The Express on lower voltage?
Post by Mark »
I was wondering if anyone has tried their Express on the 260vac power supply secondaries as opposed to the normal 300vac secondaries?
I guesstimate that would drop 50VDC from your rail voltage, I suspect the timbre of the amp would be affected as it wouldn't be as bright, though it may break up sooner.
The other thought is having a pentode/triode switch on the amp. Surely these two moves would lower the volume but change the timbre of the amp. It may not be a bad thing though.
Yours Sincerely
Mark Abbott
andresound
Re: The Express on lower voltage?
Post by andresound »
Pulling up a chair
There must be someone here Who has tried an Express with VVR?
andresound
Martin, I built an express with VVR. With a 20% reduction (I’m guessing, will have to measure voltages), the VVR is much better than a attenuator in my opinion. When reducing the express to 50% (approx 5 the dial), the amp looses feel and becomes fizzy). In the file section, I have placed a YouTube clip with a Tele. In that video the VVR was set to 7. That would be the maximum attenuation I would recommend.
https://youtu.be/Zbu3kGnudc4
Here is one with a humbukers.. https://youtu.be/1zZlKMMKls0
Has anyone ever liked triode modes? It always takes the face right off of an amp.
I can see a good outcome with lowering voltages on an Express. Softer but still with face would be great.
andresound wrote: Wed Nov 07, 2018 2:36 pm Martin, I built an express with VVR. With a 20% reduction (I’m guessing, will have to measure voltages), the VVR is much better than a attenuator in my opinion. When reducing the express to 50% (approx 5 the dial), the amp looses feel and becomes fizzy). In the file section, I have placed a YouTube clip with a Tele. In that video the VVR was set to 7. That would be the maximum attenuation I would recommend.
I really like the body of cleaned up with humbuckers. That's a great tone!
andresound
Thanks. iPhone recording, so higher gain sound suffers (compression)
