60/40 solder. What brand
RockinRocket
I used to drive down to my local Radio shack and use their branded 60/40 solder..
now that they closed what should I use? Silly question but what do you folks recommend for something that works and flows well?
Re: 60/40 solder. What brand
I use Kester also, but prefer the eutetic alloy, 63/37. Plenty to read online about eutetic solder, no disadvantages I’ve found.
RockinRocket
Sounds good fellas. Was just curious.. saw some crazy cheap stuff on ebay from china.. lots sold. Don't know.
I needed some in a pinch last weekend and the only stuff I could find local was at home depot, lead free and very little flux.. absolute garbage and the joints didn't look shiny.
Ill just order what you guys recomeded.
WBT silver, if someone else is paying.
I'm sure I am the odd man out. Early on, I developed a preference for Radio Shack silver solder. IIRC, 96% silver 4% tin. I guess I won't be seeing that again. It came in small tubes for about $3, so it didn't hurt to buy it, but by the ounce it was expensive. Bernzomatic makes a similar product that I was getting at Sears, LOL, the local store closed last year and the next nearest isn't convenient at all. I bought a roll of 96.5% silver 3% tin 0.5% copper and I can't recommend that one at all. It's likely the next time I need solder, I'll get Kester 60/40 or the stuff xitan mentioned. The store where I was buying that also closed up. I see a pattern here. The next question ought to be, where do you buy it and how much do you have to buy to make an on-line order cost effective?
I used Radio Shack solder for years but then Ampgarage guys turned me onto Kester and I never tried anything else but I'm sure there are many other brands worth trying.
My Dad was a TV repairman and he had several pounds of Kester solder from the 50s. I inherited the solder when he died in 1973. I have used about 2 pounds of it and still have about a roll and a half. Still good after all these years. Great solder. I have also used Radio Shack solder and it was good too.
Mike
Mike
RockinRocket
I ended up ordering a pound from AES for 30ish.. bought some tubes to get the free ship.
Gotta wait a week though for the slow free post.
The economics of solder purchases. I'd be pushing up daisies before I finished a pound. 1lb/$30 vs 1/4oz/$3. Hmmm.... 64* $3 = ~$200! Yikes!
RockinRocket
Maybe my remembery isn't what it used to be, but I'm fairly certain 2 x 0.25oz sleeves of solder is the most I've ever used for an amp. I build small amps. If you are building 2-channel preamps with 4 tube power sections, it' sounds quite reasonable to use about an ounce per amp. I am very stingy when I solder, careful to use just enough and not too much. Style might easily account for the difference. It's a question of interest probably only at a place like this. Maybe we should take a pole?RockinRocket wrote: ↑Sat Jan 13, 2018 2:08 am1 pound is about 12 - 14 amps for me..
I must be doing something wrong![]()
- dorrisant
I go through a pound of Kester roughly every 6 months.... Let it flow, let it flow, let flow.
On average, I'm building 2-3 amps at any time... Right now, I have 6 going. No joke...
You must mean the earlier stuff from RS? ...or maybe the batch I got was bad. I got a bunch of rolls from a closing store in Myrtle Beach for dirt cheap, It always cures very dull and dirty looking.
I threw it in the junk drawer and use MG Chem Sn63/Pb37 with great results.
