Monkeymatic Black Butte (univalve build)
Re: Monkeymatic univalve build
Applied gun stock oil, shielded inside with copper foil, applied orbital sander to bottom plate and attached to cabinet.
Progress pix.
Really cool project that turned out looking good.
Having wired up the heaters, I have a question about the DC heaters for the preamp tubes.
I'm reading 8.4vDC between pins (4+5) and 9.
I have 6.7vAC heater tap. So, 6.7 x 1.4 (FWB, cap input) = 9.38, subtract one volt for the two diodes, gives 8.38vDC. Even when the heaters drop to 6.3v under load, the DC heaters will still be 7.82v.
Do I need a voltage regulator? Why didn't THD use one? How can this circuit work properly?
See here for schematic: https://tubeamparchive.com/viewtopic.ph ... 60#p379458
pompeiisneaks
Site Admin
Post by pompeiisneaks »
xtian wrote: Tue Dec 05, 2017 1:46 am Having wired up the heaters, I have a question about the DC heaters for the preamp tubes.
My first guess would be that heaters have a max rating, depending on tubes, of 50 to 100V. I've looked up the typical 12A*7 types and they all seemed to be 50V, and power tubes I looked at (EL34) were 100. This is where they tend to burn up. Otherwise you're just generating more electron flow. It may still shorten the life of the tubes, but I don't think it will cause any kind of failure to operate (chooch as a known youtube canuck calls it).
pompeiisneaks wrote: Tue Dec 05, 2017 2:49 amMy first guess would be that heaters have a max rating, depending on tubes, of 50 to 100V. I've looked up the typical 12A*7 types and they all seemed to be 50V, and power tubes I looked at (EL34) were 100. This is where they tend to burn up. Otherwise you're just generating more electron flow. It may still shorten the life of the tubes, but I don't think it will cause any kind of failure to operate (chooch as a known youtube canuck calls it).
Heater voltage should be 12.6 for series, 6.3 for parallel. Most folks recommend doing something to lower the heater voltage if it's up in the 7.x range. What are you talking about?
didit
Post by didit »
xtian wrote: Tue Dec 05, 2017 1:46 am Do I need a voltage regulator? Why didn't THD use one? How can this circuit work properly?
Loaded or open unloaded? Reasoning behind the separated filament windings on the original schematic. Recommend reading up on transformer regulation. This varies across brand/models. Apparently somewhat expensive to achieve. THD would get a transformer that holds closer to spec for 2x300mA static load?
Speculated of course .. Ian
Yes, unloaded--good point. I loaded the tubes and tested, and I get 6.6v on the heaters. Not bad. Thanks, Ian!
Finished and play testing.
PTP is a PITA.
Final layout.
I am having trouble with ringing and oscillation. I've done quite a bit to try to isolate the issue.
When power tube is pulled, just V1 and V2 installed (both preamp tubes are required to see the issue). As I turn up Volume, I can see the "ring" (photo attached), and this "ring" reaches 100v p-p at the output of V2b.
(When the power tube IS installed and I turn up the volume, it breaks into oscillation at about 10KHz.)
I have tried adding a 22K grid stopper to V1b, tried 250p across anode and cathode of V1b. I have tried several different preamp tube swaps.
But, with V2 pulled, V1 does not show any signs of ringing or oscillating, so I guess I need to focus next on V2.
Notice that V1b and V2a are DC coupled. Can I add a grid stopper to V2a?
Any other tricks?
I added a 22K grid stopper to V2a. No change.
dorrisant
Post by dorrisant »
Very nice!! Expect clones... at least one from here. Sorry you are having issues... subscribed.
tictac
Post by tictac »
Your grounding looks "daisy chained" to me; could the way you're using the volume control lug as a star ground point be an issue?
Maybe try adding a grounded copper buss wire, separate the grounds and attach them to the buss....
Just a thought...
TT
Colossal
Post by Colossal »
Xtian,
Are you running that NFB/presence control on the fake PI? Maybe disconnect the feedback temporarily...
