One stop shopping?
galtjunk
One stop shopping?
Post by galtjunk »
Is there any place that carries most of what we need to build an amp?
In the past I used Mouser and Cedist to get most of what I needed.
Mouser doesn't have very many axial caps anymore.
Has anyone used the 27000 hour rated kemet caps?
Rockwell666
Re: One stop shopping?
Post by Rockwell666 »
tubedepot.com is where I get a lot of stuff from.
pompeiisneaks
Site Admin
Post by pompeiisneaks »
I personally avoid tubedepot like the plague, I had an outstandingly horrid customer service incident there once, and never again.
I think often you have to use multiples. I like CEDist and Mouser.
As for axial caps, from all I've read most of us should just move to using radials, as they're more common, way cheaper, and the nicer brands work perfectly for audio. People can confirm or deny these as quality, but from what I've heard/read, Panasonic, Nichicon, and Kemet are a few of the higher end caps out there. (in the electrolyic range anyway). They're way smaller, and way less expensive than the radials, due to the higher demand for them. Basically you get the exact same performance and quality just in a slightly different form factor (and did I mention way cheaper?).
I shop all over the place: CEDist, Mojotone, Mouser, Digi-key, and E-bay.
drew
Post by drew »
pompeiisneaks
Site Admin
I really, really like hoffmans site, but he also doesn't have everything, his focuses more on extremely commonly used components, or components used by his kits he's built up. I wish he held more, and I'd buy more often from him. I still do, but now that I'm building a lot more heavily, the cost of the other sites, and the broader selection means I go there more often than not.
jjman
Post by jjman »
Here's my compilation in my bookmarks. Many are old.
Allen Amplification
Amp Maker - Guitar amp kits
Amplates.com
Amplified Parts
Angela Instruments Online Catalog
Antique Electronic Supply
Apex Jr. Supplies
BYOC
CE Distribution (Wholesale)
CeriaTone.Com - DIY Guitar Tube Amp
ClassicTone Transformers By Magnetic Components, Inc.
CommonSense Audio
DigiKey Electronics
DIYguitarist.com Home Page
Dougs Tubes
Dynakitparts.com
EDCOR - GXSE Series Output Transformers
GuitarandAmpParts.com
Guitar Nucleus Parts -
Heyboer Transformers
Hoffman parts
JLM Audio Shop
JMI parts
Just Radios
KCA Tubes
Marsh Amplification
Mercury Magnetics
Mission Amps
Mojo
Mouser
Musical Power supplies Transformers
Newark.com
Parts-express.com
Retro Sound
trmguitarcabs.com
stewmac.com
STF-electronics
THETUBECENTER
thetubestore
Surf Bug Trem roach
TubeDepot.com
TUBEMAN.COM
TurretBoards.com
vacuumtubesinc.com
VacuumTubes.net
Vibroworld.com
Weber Speakers
lord preset
Post by lord preset »
pompeiisneaks wrote: Tue Oct 24, 2017 2:40 pm
But they look wrong. Is nothing sacred?
galtjunk
Post by galtjunk »
Is the 27,000 hour rating on the Kemet 33uf 450v axial cap for real?
Mouser doesn't have stock but digikey does.
The price difference isn't much if you consider that rating.
Post by Stevem »
AES is my go to but for the 3 watt 100k metal film plate resistors I use a lot.
pompeiisneaks
Site Admin
galtjunk wrote: Wed Oct 25, 2017 9:26 am Is the 27,000 hour rating on the Kemet 33uf 450v axial cap for real?
I guess I got lucky, I ordered the 4 I needed for my Tweedle Dee Deluxe and they had enough, maybe I bought the last :P
https://www.mouser.com/search/ProductDe ... 4YJ2330QL1
