New 5F6A Build Issues
Re: New 5F6A Build Issues
I have a fresh set of TAD 6L6GC's which are rated around 30W,  as well as a GZ34 rectifier coming tomorrow. I think what I may do, in the meantime, is install a bias pot, to simplify things.
						- pompeiisneaks
- Site Admin
Yeah it's a good idea, the Hoffman version comes with adjustable put and I loved it.  Traded the amp though.
Sent from my HTC 10 using Tapatalk
So, I've installed a 25k linear bias pot, and replaced the 56k bias resistor. (First with a 27k, but it biased too cool, so I twisted two 10k's together, and that got me down into acceptable range, right around 41.5 mA.
I'm going to spend a little bit of time tonight triple checking my connections and solder joints, and then, what's the next step ?
What are the power supply node voltages now (measure to ground from each filter cap)? Do you have 6L6GC's and a GZ34 installed now? I would check for voltage on all the preamp tube pins 1 and 6 without tubes, and if they look reasonable (something close to the PI filter's voltage) you can put all the preamp tubes in and measure all pins 1 and 3, and 6 and 8. Plugging in, you should get sound, unless there is some other issue lurking.
Your lucky pin 6 is not used on those tubes!
With 6L6WGC's and GZ34 installed, I'm getting 430 to 432v DC on the filter caps, and 426v DC on V1, pins 1 & 6, 422, and 426 on pins 1 & 6, V2, and 423 and 421 on pins 1 & 6, V3.
Upon firing it up after installing preamp tubes, it made a noise that made my wife exclaim (in faux British royalty accent) "Oh Darling, is that the Queen Mary ? She must have made record time !"
It did sound a bit like a ship's horn.
Power stage plate voltage looks good. Perhaps your primary leads are reversed, and your NFB is PFB?
I reversed the (blue and brown) primaries, and it did eliminate the foghorn. Now I read -43 on pin 5 of each of the power tubes, but nothing on the resistor to ground off pin 8.
Also, all of the tone pots make a "whoosh" sound, like a presence control when rotated, this doesn't seem normal either.
So no current flowing at the power tube cathodes, yet you have some sound... that's odd. What voltage do you have on pins 3 and 4? Can you post some photos?
Okay, now I'm getting better readings. Pins 3 and 4 are 412.8vDC and 411.6vDC on V4, and 411.0 vDC and 410.8 vDC on V5.
V4 pin 8 = 37.7mvDC, and pin5 = -43.93vDC
V5 pin 8 = 43.1mvDC, and pin 5 = -43.89mvDC
On the preamp tubes, I'm getting the following:
V1- Pin1=160.8vDC, Pin 3= 1.0vDC, Pin 6= 161.6vDC, and pin 8 = 2.40vDC
V2- Pin 1= 177.8 Pin 3 = 1.0 Pin 6= 305. Pin 8= 179.
V3 - Pin 1= 240. Pin 3= 39.78 Pin 6= 240. Pin 8= 39.78
Voltages all look good except V1 pin 3 seems low. It should more or less match pin 8, like pin 1 matches pin 6. Could that be a measurement error? Do you get sound?
					Last edited by martin manning on Sat Jul 22, 2017 10:55 pm, edited 2 times in total.
I get sound, but there is a bit of a crackle. Actually, apart from the crackle, it's pretty stellar sounding.
Let me re-measure.
						Let me re-measure.
Note the 2.4 V is more like the expected cathode voltage, and since they are tied together they should be identical. Crackling could be bad solder joints, or poor contact between tube pins and sockets. Poke around with a chopstick to look for sensitive areas. Note with 180 V on the cathode of V2, the heater-cathode insulation is highly stressed. That tube should have 200 V spec for Vh-k.
					Last edited by martin manning on Sat Jul 22, 2017 11:00 pm, edited 1 time in total.
They are, indeed, identical. I must have written it down wrong. I'm going to do a little chopsticking, and see if I can't chase down that crackle, but other that, it really sounds fantastic.
Thanks so much for the sage advice and direction.
If I get brave, I may post a clip or two.
You're welcome, glad you've got it working. I'm wondering why you lost voltage on the power stage cathodes at one point. Definitely poke around for an explanation.
