Normster's 6V6 ODS layout
Is that layout still untested?
I'd like to build an ODS with verb..............
IS there a companion schem?.
Thanks a million
Aharon
Thanks a million
Aharon
Aharon
Re: Normster's 6V6 ODS layout
Actually, I finished that build awhile ago. Finished pics and clips are here:
http://www.adlibmusic.net/normster_amps ... /index.htm
I ended up building it with #124 preamp values but may change it back to hybrid-a. The last layout posted is this one:
http://www.bad-domain/6V6_ODS/6V6_ODS_124.JPG
I pretty sure I updated all changed values, but there are so many tweaks along the way it's possible I missed one or two.
As for schematics, I usually just refer to the hybrid-a and draw in other circuits as needed when I do the layout.
Oops, forgot to mention...I did NOT build the FET.
Thanks a lot Normster,nice clips.....great sound.
I might ask you a couple of questions as I go along.........I have to finish a couple of projects and then I'll start with the ODS.
Aharon
Aharon
Aharon
Any chance the links can be corrected to where we can see those files?
- pompeiisneaks
- Site Admin
His site is offline, so no, we can't connect to a site that no longer exists. Sadly. I guess we could look at the internet archive if his site was archived... I'll try that.
- pompeiisneaks
- Site Admin
No luck, looks like his site was archived but with no direct links to the images, so they weren't archived.
thanks for trying!
Paging mfowler . . .
Guitarman18
2 others liked this
I believe this is Normster's original 6V6 ODS layout. I hope he doesn't mind me posting.
Paul.
Paul.
'Beauty is in the ear of the beholder'
That's a basic Brownnote D'lite, Norm's was different. IIRC, Norm's ODS version was a quad 6v6 version with reverb.Guitarman18 wrote: ↑Mon Jun 26, 2017 4:20 pm I believe this is Normster's original 6V6 ODS layout. I hope he doesn't mind me posting.
Paul.
TM
Found it
TM
TM
thanks guys . this will help. if normster sees this post and has the editable visio drawing, that would be great. he can pm me. I am otherwise creating an editable version with 'connected' connections.
- pompeiisneaks
- Site Admin
I don't know that it's likely. He's not been active here for a while, and I know someone here that told me they see him active on a few FB groups and he's not responded to requests about the site and files. We can always hope though.
This is voiced different it also has a built reverb it must be a deluxe model for sure! The first cap to the right Mid cap is a. 01 rather than a. 05 mfd like in the 124 I wonder which Dumble he used for this one? I wonder how well the reverb sounds wired this way without the dumblelator impendence matched buffer cicuit? This would be cool in a 50 watter or 100 not a big fan of the HRM so this might different.. I built a ceriatone HRM and a standard overtone and looking for something more blooming overdrive.
