Reconnecting reverb wiring to a Marshall 4210
Marshall Amp Discussion
Like a fool when I cut the wires I didn't mark or record which of the reverb tranny's pins the return is wired to. The schematics are enigmatic.
Anyone know or have a gut shot of the reverb tranny on a 4210 or 2205?
Re: Reconnecting reverb wiring to a Marshall 4210
Post by Stevem »
There is not a red and Blue wire off of the reverb driver trans, as that is the primary / high voltage side.
The primary side will also test out at a far higher resistance then the secondary side.
Stevem wrote: Mon Jun 19, 2017 10:43 am There is not a red and Blue wire off of the reverb driver trans, as that is the primary / high voltage side.
Hi Steve,
Can you translate that into electronic dumb ass for me?
Post by Stevem »
Are you taking about the reverb pan and questioning which end / cable is the return side?
Hi Steve,
I'm looking for which tap on the Reverb tranny the return wire is connected to. I took a pic when I bought it but can 't see where the wire goes.
Thanks for your help!
Here's a 2959 Lead with the same transformer. I'd guess the red lead goes to the PI node and the blue to the driver tube plate. The coax goes to the reverb tank input.
Link: http://www.marshallforum.com/threads/ma ... 00w.95834/
Hi Martin,
Thank you, that's what I need!
Post by Stevem »
The first rule for taking anything apart that you are not intimately familiar with is making notes my friend!
Many times the 2 minutes spent doing such saves hours!
10thTx
Post by 10thTx »
Taking notes and lots of high resolution photos prior to taking things apart OR modifying/changing anything,
:wink:
