Larry carlton ported/sealed EVM-12-L cab made
- norburybrook
Got round to buying some tools this weekend so made this.
Dumble Larry Carlton 1x12 ported Sealed EVM12-L cab. Going to recover my #102 to match.
As this is a sealed cab should it have any kind of internal wadding?
Marcus
Marcus
						Re: Larry carlton ported/sealed EVM-12-L cab made
Looks great!
I like the colors you choose. I am looking for VOX grill cloth for a dumble build that I maybe doing soon. Is that brown or black vox cloth and were did you get it?
Cheers
Guy.
Cheers
Guy.
Very professional looking cab, that will be a nice looking rig with matching head on top.
				tealsixtysix
Looks great. It's like a Thiele cabinet but maybe a bit bigger?
Marcus, looks great! Are there drawings or dimensions somewhere for this cab?
				telentubes
That looks really good. Also interested in design specs, and tone report when you get it plugged in.
				andresound
Dimensions/drawings please!
						- norburybrook
I took everything from this picture and scaled the measurements from the width of my amp which is 20 inches wide in your languagemartin manning wrote: ↑Wed May 10, 2017 12:59 pm Marcus, looks great! Are there drawings or dimensions somewhere for this cab?
I think the height was 16 inches and the depth is the same as the amp 10 inches.
ports are 4 inch diameter from tube town Germany.
Any thoughts on internal wadding?
Marcus
Thanks Marcus. I don't know too much about speaker design, but that is basically a ported bass reflex like the TL808. You can find a build document for that published by EV, and I would follow their recommendations for stuffing.
Nice cab Marcus! I like the first pic: explosion of tools
The ported cabs I have(thiele) dont have wadding. It sounds fine to me.
Doesn't wadding alter the resonance frequency because the internal volume changes?
				andresound
My 2c worth. I built 2x TL EV cab's and was impressed when loaded with EV. However... the Dumble "rear oval" open back speaker design from this forum sounds much bigger than the theile design. My go to small cab
				andresound
Bass frequencies don't "see" the wadding
Andre,andresound wrote: ↑Fri May 12, 2017 4:29 pm My 2c worth. I built 2x TL EV cab's and was impressed when loaded with EV. However... the Dumble "rear oval" open back speaker design from this forum sounds much bigger than the theile design. My go to small cab
I have done a lot of reading on this. I have long considered a pair of Thiele TL806s for a very compact stereo rig. I have read that they are directional but have a huge, clear sound with exceptional punch. I have EVs and like them. For me, it's not about volume, but the stereo 3D spread and bubble. Now, in a smallish room, an open backed cab(s) can have that music-from-everywhere sound because of room reflections and dispersion. So for you, do you feel that your choice for a D-open back being better for your application is based on the room size or just the aural qualities the D-style open backed design brings versus the Thiele/EV?
What speaker are you using with your Dumble open back?
						- norburybrook
thanks guys,
I have a proper EV thiele cab and this doesn't sound the same. I know it's a similar design but the thiele is more or less a cube and is supposed to have wadding on the back and all sides excluding the port.
this cabinet has a different sound to a thiele and I prefer it, it's easier to mic in the studio/live and has a sound I prefer.To be honest, I think most guitar speaker cab dimensions etc are not that scientific/critical and very tolerant of size, material. I mean look at open fender backed combos, you've basically got a speaker attached to a baffle with random panels on the back. The Marshall 4x12 dimensions were chosen because they could make it from a single 8ftx 4 ft sheet of plywood.
I might try some acoustic wadding just to see, if I do I'll report back.
I'll mention the fact that for speaker cabs (and my amp heads if they're tolexed) there is absolutely no need to do any fancy joints if you're using 18mm(3/4) plywood. I just screwed and glued, the front baffle gives the whole cab rigidity so it's a very simple thing to make with basic hand tools. I used P38 quick dry car body filler to fill over the countersunk screw holes , then a quick sanding and routing of edges.
I found it very therapeutic spending the day making it after a long week in the studio.
Marcus
Marcus
						- norburybrook
I've got both. The sealed cab gives you that pressure wave push in the trousers that a 4x12 gives you and is friendlier to other band members as the sound is more directional. The oval backed cab is a great alternative, I put celestion classic lead 80's in them ..the 16 ohm version...spent a day with a pile of speakers and that was the best, and the 16 ohm sounded better than the 8 ohm with my #102.Colossal wrote: ↑Fri May 12, 2017 4:59 pmAndre,andresound wrote: ↑Fri May 12, 2017 4:29 pm My 2c worth. I built 2x TL EV cab's and was impressed when loaded with EV. However... the Dumble "rear oval" open back speaker design from this forum sounds much bigger than the theile design. My go to small cab
marcus
