Iris combo cab
Iris combo cab
So I built this for the 2017 Dallas Guitar show as a booth amp 5/5-7/17. 1987 in a curly maple, canary and walnut finished with an orange water based stain and linseed oil / mineral spirits.
I plan to build a curly maple iris similar to the pic below. Surprising how much orange the blue human iris has.
Found some curly maple with good figure that was wide enough to form the iris to fill the combo cab baffle.
Then cut most of it away to fit. Always a nervous moment as I tend to be a 'Ready, Fire, Aim' guy.
To put the orange in I carved the 'figure' in with a dremel then bleached the wood with a two part solution. Stained the wood with yellow and orange then filled it with epoxy. Sand flat.
Bleached again then rubbed in blue fabric dye, to be shown in the next post.
Re: Iris combo cab
OMG. Phil, is there a "Like LOTS" button available?
pompeiisneaks
Site Admin
Re: Iris combo cab
Post by pompeiisneaks »
Yes, if a lot of us like it (that's two) ;)
Re: Iris combo cab
Whoa...Adobe is reading your mind...
pompeiisneaks
Site Admin
Re: Iris combo cab
xtian wrote: Thu Apr 20, 2017 6:03 pm Whoa...Adobe is reading your mind...
LOL :D
I see that one a lot, I use adobe products all the time
Edit: specifically Premiere Pro to edit my Youtube vids
Re: Iris combo cab
Thank you for the kind replies - that adobe thing is giving me ideas....
Here's the iris rebleached and the blue dye rubbed in. It's matte at this point
Now with 3+ coats of automotive clear brushed on
And wet sanded with 400 grit to level and give the paint a grip.
Now I gotta relearn how to use a two stage airbrush.
Re: Iris combo cab
Some good looking stuff right there. :D
Re: Iris combo cab
Russ, you keeps amazing us with your creativity! May I say, this one is eye-popping! <groan>
Re: Iris combo cab
Your idea would look nice as an acoustic guitar top, pupil as soundhole.
stelligan
Re: Iris combo cab
Post by stelligan »
It's threads like this that keep me hanging out here. So much talent and creativity on ampgarage.
Super cool cab, man :!:
Re: Iris combo cab
Getting closer to the finish line. I airbrushed in white highlights and some translucent orange on.
I liked the effects but I wasn't happy with the presentation - it didn't said EYE. More black hole on acid. After consulting with a artist friend I sprayed on some white accents.
AYE! - sorry couldn't resist. Three coats of automotive clear later...
I sprayed white on the pupil as a reflection but it was in the wrong place so I plan to redo it.
Re: Iris combo cab
Now, obviously, you need TWO of them, side by side.
Re: Iris combo cab
xtian wrote: Fri Apr 28, 2017 3:17 pm Now, obviously, you need TWO of them, side by side.
I intended to do just that by book matching the angled pieces. When I cut a couple apart the pieces warped badly - so it will be a cyclops amp.
Re: Iris combo cab
Fixed the FUBAR'd reflection on the pupil and sprayed a bit of lacquer to make it somewhat shiny.
Next will be to clean the disaster I call a shop and contemplate the next project as I don't do postpartum project depression well. Then I saw this and thought HOLY CRAP! A 2x12!
JazzGuitarGimp
Re: Iris combo cab
Post by JazzGuitarGimp »
That looks like a 2x12 AND 2x15 all rolled up into one!
