Thanks ,the last night ,I ve found a lot of advices about hiss,here againM Fowler wrote:Congrats on your build.
All the things you noted are common with this amp.
For that presence circuit you may need to move the wire from pot to impedance selector around and see if that helps.
I will try to make a separate ground for the presence pot.
