 Anyway, Eddie got more into the rock thing and the brown Princeton was heavily modified(butchered). The customer wanted it put back to stock but nothing was original to the amp and it had a bunch of added holes, so I built him a dead stock new amp to put in the cabinet. I used a Mojo chassis, Mercury transformers, Sozo caps, and NOS Allen Bradley resistors. As you can see, I really wanted to use the Mercury power transformer and had to improvise to get it to mount. Amps sounds great. Even with the customer supplied Sovtek 5Y3 rectifier the B+ is at 344vdc. We are going to get a GE 5Y3 which should drop the voltage a bit more. I guess the 315vdc on the Fender schematic may not be such a myth after all.
 Anyway, Eddie got more into the rock thing and the brown Princeton was heavily modified(butchered). The customer wanted it put back to stock but nothing was original to the amp and it had a bunch of added holes, so I built him a dead stock new amp to put in the cabinet. I used a Mojo chassis, Mercury transformers, Sozo caps, and NOS Allen Bradley resistors. As you can see, I really wanted to use the Mercury power transformer and had to improvise to get it to mount. Amps sounds great. Even with the customer supplied Sovtek 5Y3 rectifier the B+ is at 344vdc. We are going to get a GE 5Y3 which should drop the voltage a bit more. I guess the 315vdc on the Fender schematic may not be such a myth after all.CW
