It is "as possible as small size/loud output".
I want to loud cleantone volume that can beat the drum sound.
I thinked at the first time, the el84 is most suitable output tube for this purpose.
Because they have very tiny size and can get 15~25W output with just two tubes.
People says the 15~20W tube amps have enough clean volume output that can beat the drum volume.
But I made and used many 15~20W full-tube amps,(vox ac, marshall 18watters, Laney lc15, blues junior and etc...) and then I realized it was not true.
They can mix with drum volume only if they breaks up or make crunch tone. When play it with pure clean tone, I can't find the existence of my guitar tone.
The 6v6s have the same result with EL84s.
With the small size it has, help me to make the amp small, but unfortunatly, the clean volume is not enough to me.
(I made Princeton reverb, Deluxe reverb, Dumble lunchbox and etc.)
The final point of compromise that I found is Hammond 35W with 5881.
When I use hammond Pro reverb replacement output transformer with 5881 pair, I can get barely enough clean volume in a small box.
Is it impossible to make loud clean volume with EL84 pair?
The EL84s that I used are all insufficient.
But I have not used mesa mini heads that has EL84 pair.
They introduced it has 25W, and people says it has very loud clean volume.
But I can't trust the EL84 pair amps because of the EL84s that I used.
Does anybody used the Mesa EL84 25watters in ensemble with cleantone? Does it has enough output?
If the output is enough, why the Mesa EL84s are different?
I want know how can get 25W output with EL84 pair.
I make a Dumble with Orange Tiny Terror sized chassis. It has 35W OT with 5881.
I can get the satisfaction with It. Very small, enough loud.
But if I can get enough loud clean headroom with EL84 pair, I want to make more small clean amp for pedalboard.
Wait for your advise.
