TW Rocket
Blues Hound
Re: TW Rocket
Post by Blues Hound »
Martin,
Sorry of the typo, Pin 6 is 258.5 VDC.
I will check the cathode resistor, to make sure it is 1.5k.
Thanks,
Steve
Bob S
Re: TW Rocket
Post by Bob S »
I like that B+ voltage. 300 to 310v is a good place imho.
A little gentler on the output tubes.
6p14p is the basic Soviet version of an el84. The ev suffix is a select version (longer life or some such). There's a k suffix for something else - might be hardened/less prone to vibration. One of our experts might chime in.
They're all good anyway & you can beat them like a 7189.
Dr Z might well have bought the majority of them.
Oh & good catch Martin.
Nice build!
Why Aye Man
rp
Re: TW Rocket
Post by rp »
Bob S wrote:6p14p is the basic Soviet version of an el84. The ev suffix is a select version (longer life or some such). There's a k suffix for something else
This is from one of the good people here that i saved:
The Sovtek EL84M *is* a rebranded 6П14П-EB = 6P14P-EV - same Reflektor factory, same tooling, same templates, same construction, same materials, same everything. Ditto for their EL84 = 6П14П = 6P14P.
Some NS-sourced batches can be quite poor because of sloppy production and lack of real QC. Vintage OTK models - I would say pre-1983 or so - are much better in that respect, they can still be found from Eastern European (r)etailers.
Russian suffixes:
P (Cyrillic) = R (Roman) = special quality
E = E = extended lifetime
B = V = ruggedized
K = K = vibration resistant
Russian equivalents of the EL84:
6П14П; bog standard version, large thick glass = EL84, 6BQ5
6П14П-EB; hardened version, longer lifetime = EL84M, 7189
6П14П-EP; special quality, longer lifetime = E84L, 7320 (quite rare)
6П14П-K; hardened version, vibration resistant = EL84F (very rare)
Blues Hound
Re: TW Rocket
Martin,
Apparently I am s bit dyslectic or color blind, as it was a 1.2M.
Swapped it out for a 1.5K, all voltages are looking very good and the amp sounds very good.
Pin 1 V1, Pin 2 V2 115.2 VDC, Pin 3 V2 115.1 VDC
I am in your debt sir...
Steve
Re: TW Rocket
Not at all, Steve. The complete set of voltages and good pictures made it easy.
Blues Hound
Re: TW Rocket
Bob and RP,
Thanks for the information, I currently have JJ's in and they sounds very good, is there a big difference between the JJ's and the Sovtek's?
Steve
Blues Hound
Re: TW Rocket
I have seen that others have built 2x EL84 Rockets, would it be possible to put in a half power switch ala Dumble and run it with just two of the EL84's?
Thanks,
Steve
Re: TW Rocket
You would need to double the cathode resistor value and double the speaker load (mismatch the impedance selector down one click).
Bob S
Re: TW Rocket
Post by Bob S »
If the 6p14p's are 70s they are as good as any nos el84s - European or US made, to my ears anyway.
It might be that I'm unlucky, but I've never had much luck with JJs.
Some are good, but some aren't.
Why Aye Man
norburybrook
Re: TW Rocket
Post by norburybrook »
I bought some Russian valves for my rocket/Z-wreck from a guy in Russia via Ebay. They're great, I had one red plating JJ so thought I'd give the Russian valves a try. The rocket/wreck runs the output valves very hard.
M
Blues Hound
Re: TW Rocket
Tried some Ruby 7025/12AX7's in the Rocket...way more treble...put the Mullard's back is as I think they sound better...going to try the Ruby's in the Express clone...
Have a quad of the Russian 6p14p-cv's on the way, will report back after I get them.
This amp is becoming a favorite...
Blues Hound
Re: TW Rocket
Quick update:
Had the quad of the Russian 6p14p-cv's in the amp for a while and ended up putting the JJ's back in...they just sound better.
Steve
Re: TW Rocket
I find that JJ's are much better tubes myself.
