Big Britches 6G3 Built Chassis
Fender Amp Discussion
dcribbs1412
Re: Big Britches 6G3 Built Chassis
Post by dcribbs1412 »
ToneMerc wrote: When I get home later I might install the pair of JJ 5881's. I think if I install a JJ 12ax7 at V1 the voltage will drop an additional 8-9 volts. I will roll some tubes and get a baseline on where the voltages will fall using the small and big bottle power tubes.
Head cab, not sure whether blonde or brown. I think blonde would be kind of cool.
TM
Nice plan
Agree about blonde, are you using brown faceplates?
D
ToneMerc
Post by ToneMerc »
Brown plates
TM
ToneMerc
Post by ToneMerc »
Installed two balanced JJ 83's in V1 & V2 and JJ 5881's in V4/V5 with no other changes.
V1: 171.2, 160.3
V3: 242.7, 236.8
Bias: V4= 35.1, V5= 32.0
V4&V5: 389 plates, 382 screens
TM
dcribbs1412
ToneMerc wrote:Installed two balanced JJ 83's in V1 & V2 and JJ 5881's in V4/V5 with no other changes.
V1: 171.2, 160.3
V3: 242.7, 236.8
TM
Nice!
How is she sounding
D
ToneMerc
Post by ToneMerc »
dcribbs1412 wrote: Nice!
How is she sounding
D
Thanks!
Good question, after I changed tubes it sat idle on the dummy load for about an hour. Hopefully I will get chance to hear it this weekend if I'm not playing with drones.
TM
dcribbs1412
How is she sounding
D
Thanks!
TM
Looking forward to your future posts
btw drones? sounds interesting
Always thought one could probably have a blast causing trouble in a populated area :)
D
ToneMerc
Post by ToneMerc »
dcribbs1412 wrote: Always thought one could probably have a blast causing trouble in a populated area :)
D
A blast causing trouble in unpopulated areas as well...LOL
TM
ToneMerc
Post by ToneMerc »
V1: 171.2, 160.3
V3: 242.7, 236.8
TM
Rolled V1&V2 tubes and reflowed a couple of solder joints with no other changes.
V1&V2: JJ 83S
V3: Sovtek LPS
V4&V5: JJ 5881
Rect. Tube: Ruby 5AR4
PT: 120V, 300 - 0 - 50 - 300
Mains: 122.2
V1: 166.5, 172.8
V2: 168.3, 210.7
V3: 244.5, 238.3
V4: 391, 385, 35.1
V5: 391, 385, 32.0
Dropping string : 680R>9.1K>27K.
Screen resistors: 1K
TM
joeboo88
Post by joeboo88 »
Hi ToneMerc:
I am staring to build one of these, and was going to add a bias Pot
like you have.
what size of resistor on the pot ( lug1?) do you have going to ground?
also you said you are using 5881's ~ is that tranny TO40 - a 4k?
I'll probably use 6v6's as I have a 6.6k 20 watt OT
Very nice build, thanks, Joe
ToneMerc
Post by ToneMerc »
joeboo88 wrote:Hi ToneMerc:
like you have.
2W-10k and correct, a 4K OT......thanks
TM
Bob S
Post by Bob S »
How does she sound TM?
I'm thinking about a 1 x 12 combo build. Might add reverb.
Exceptionally elegant build - you make it look easy.
Or we make it look difficult...
Why Aye Man
