TW iron in a high-gain Marshall-inspired build?
Has anyone used TW iron in a higher-gain Marshall style amp (with at least 2204 preamp gain)? If so, how did it work out? How did it change the Marshall tone?
guitarmike2107
Re: TW iron in a high-gain Marshall-inspired build?
Not done it, but my guess is it is going to sound like a Marshall with lower plate voltage.....
fusionbear
the amp that I play all the OD clips is a 20 watt 2204 that I built using Classictone TW OT. Worked really well IMO:
https://www.youtube.com/watch?v=e8q2yLsPBfU
Give a shot...
Give a shot...
Learning to learn...
thanks guys!
I built a JCM800 2204 with TW PT and TW Dynaclone A470-S 4k3 OT kicks ass even with the lower plate voltage.
Like the guys say, 370 - 400 volts works wonders for a 2204 type circuit.
Up to 6k sounds good for the OT imho.
TW iron works great - lots of power on demand.
Why Aye Man
After extensive testing germino started using wreck style OTs in his new low-watt plexi.
www.myspace.com/20bonesband
www.myspace.com/prostitutes
4x12" w/H75s
4x12" w/H75s
