When i plug in my liverpool its a 2 el84 version the amp
Is full volume. Not sure if a bad vilume pot would do this im just getting back to this amp after letting it sit for while
						Liverpool runs full volume
Re: Liverpool runs full volume
I think it is a ground issue with the tone stack.
Think of it as a boost that is always on.
						- JazzGuitarGimp
Or the ground at the bottom f the volume pot is missing.M Fowler wrote:I think it is a ground issue with the tone stack.
Found problem had a wire in the tonestack wired wrong.  Thanks guys
Hey, Mark, didn't you get my PMs?
I did but got juat got 2 output tranys of ebay so i dont have a use right now but thanks most my projects are lower watts 15 to 30 os pretty much my thing right now. Sorry took a while getting back with you. Mark
