Big Britches 6G3 Built Chassis
Started a new 6g3 build that will be setup to run small and big bottle tubes.
I'm making a few changes though.
1. Bigger OT
2. Adj. bias and test jacks
3. Heavier filtering (50, 22, 16, 16)
4. Adj. PI
5. Screen resistors and grid stoppers
TM
1. Bigger OT
4. Adj. PI
TM
Re: Big Britches 6G3 Built Chassis
That's a seriously hefty output transformer, what is it?
An Allen Amplification TO40 (Heyboer)Mr. dB wrote:That's a seriously hefty output transformer, what is it?
TM
That's going to be very nice
Threw some more minutes at it; power and adj. bias supply tested.
TM
TM
dcribbs1412
Looking good TM
D
D
Time to install power tubes.
TM
TM
That looks killer! And I see mojo
Looks Great. Nice use of KOA SPRs, I just wish that the were easier to come by and in more values.
Thanks Dave, I only have a few of the "legacy" Sozo blue caps left and I didn't want to use them up in the oscillator section.Colossal wrote:That looks killer! And I see mojo![]()
TM
Thanks, yeah me too! I don't why they ceased to manufacture the 1M value.John_P_WI wrote:Looks Great. Nice use of KOA SPRs, I just wish that the were easier to come by and in more values.
TM
Curiosity was killing me so as a quick test I just popped in my junk EL34 startup pair which are severely mismatched and also cold biased.
There's at least 8-10 variations from the stock circuit so I will see how this finally turns out.
Mains: 122.5
Filament: 6.5
Bias: 31.2, 21.6
Plate: 397
Screens: 386
V1:191,183
P.i.: 253, 247
V1&V2: Baldwin black plate RCA's pulls
V3: Sovtek LPS balanced
V4&V5: Winged C EL34
GZ34: Ruby
TM
Mains: 122.5
Filament: 6.5
Bias: 31.2, 21.6
Plate: 397
Screens: 386
V1:191,183
P.i.: 253, 247
GZ34: Ruby
TM
Sweet looks a lot nicer than my 6g3 build
dcribbs1412
That's a real beauty TM
like to hear what you think of differences in big vs small bottles
btw going blonde head cab or combo?
D
D
When I get home later I might install the pair of JJ 5881's. I think if I install a JJ 12ax7 at V1 the voltage will drop an additional 8-9 volts. I will roll some tubes and get a baseline on where the voltages will fall using the small and big bottle power tubes.dcribbs1412 wrote:That's a real beauty TM
D
Head cab, not sure whether blonde or brown. I think blonde would be kind of cool.
TM
