Any way its a $2795 basket-case.. Virtually un-serviceable!
So the problem is the power tubes are directly behind the speaker! Major design flaw...
The 5881's are literally 5/8" from the speaker magnet which is large (Fane) The tube sockets are not shock mounted. The fashion in which the amp is built -PTP/Component to component without turret boards etc, makes servicing difficult- its a rats nest inside! Moving a socket will disrupt just about every component in the power amp section, none of the components are isolated with jacketing etc- so any movement will result in shorts.. Need to be careful as they're not divulging a schematic or reference voltages etc.. All be it a Princeton Reverb sub vibrato and having a 6L6 power section..
Installing rubber bushings to isolate the sockets would be a major project.
The vibration is literally shaking the power tubes to self destruct, a new set of tubes, and a half hour of playing today turned a brand new set of JJ 5881's microphonic and popping to the touch.. The socket is tight- so its not a loose connection issue.. The amp chassis is mounted to the plywood cabinet in 8 locations, so lots of vibration coupling through the cabinet into the chassis between the mounts and also lots of surface area touching cab/chassis...
so big question is-
Has anyone tried isolating an entire chassis? Is it pointless?
Need to figure something out because as it sits, the way the amp is built
every month the customers going to need a set of power tubes- Or deal with microphonic power tube noise- which is a bullshit answer for a $2795 amp..
After a rather alarming chat with the builder he was rather apprehensive in acknowledging these blatant design flaws. Claiming they're not real concerns and that the massive tube isolators he includes with the amp should solve that issue..
Crock of bs..
anyway- if anyone has any ideas and doesn't mind sharing great.. I've seen allot of doozies but this takes the cake-
