Custom Preamp Project
glasman
Re: Custom Preamp Project
Post by glasman »
lovetone wrote:
glasman wrote:Front panel closeup.
I generated these panel in house on my new to me epilog Helix laser.
Looks great what material did you use for the face plate?
It is a two layer black over white plaster laminate. Very tough, Used it on my ZIngaro amps for the last few years. Much stronger than the acrylic that I used in the past.
Gary
About 5 miles south of I-94
www.glaswerks.com
glasman
Post by glasman »
martin manning wrote:
glasman wrote:To clarify for Martin, it is close to the standard CF section, I just rebias that section to get more headroom. The standard values suck and it will clip in a heartbeat.
Thanks. That means you have an unused triode?
Super low-ripple power supply and DC filaments are to be expected for a piece of gear like this.
The two halves of the triode are wired in parallel, same as I do on my Matchox two channel d-lator.
www.glaswerks.com
glasman
Post by glasman »
DenDanger wrote:
glasman wrote:This piece was commisioned by Rick Derringer of all people.
Very nice and neat. Classic look. Super job of fitting 8 lbs in 5 lb box.
Rick Derringer is one of my favorite guitarists. (Very underrated)
I don't think I've seen him use rack mount gear.
I'm sure he will enjoy it.
Denny
Rick was telling me that the last few years he has been carrying a rack style preamp that he simply runs into the power amp input of a Blues Deville, never uses the clean just leaves the preamp in Overdrive Mode. His first was built by VVT I think, guess they had an issue with the unit and decide to contact me for a new unit. I really hope it meets his expectations. Have a LOT of hours into it at this point.
But it does give me the desire to finalize my rackmount preamp for studio or stage use. started the design a few years ago and never finished it lol.
Gary
www.glaswerks.com
glasman
Post by glasman »
Yes, I went very stiff on the power supply for that very reason. Also the reason I included a choke in the design. The ripple is literally in the noise on the DC lines.
Gary
www.glaswerks.com
jelle
Post by jelle »
Looks great Gary. Very nice work. 8)
glasman
Post by glasman »
jelle wrote:Looks great Gary. Very nice work. 8)
THanks Jelle.
www.glaswerks.com
tubedogsmith
Post by tubedogsmith »
Duble wrote:This is similar to what I did, but i mounted the boards Dumbleator style.
Preamps can be tough with noise!I had to mess around with the grounding for quite a while. Shopping for a PCB house now for mine. I also did a passive and buffered output, with a full loop. Mine looks much more crude :lol: Yours looks really great Gary!
I used a full wave bridge as I'm not a fan of voltage doubler's. Had Heyboer make me a PT with a 260v secondary in an R2C frame.
Do you notice much of a "smoothing" effect with all the shielded connections.
glasman
Post by glasman »
No not really, the lengths of the cable are pretty short so there is not much net capacitance. The chassis is only 8" deep. Life would be nicer if I were to implement some right angle tube sockets lol. The space between the l-bracket for the tubes and the board is a PITA to work on. But it is a one-off and there will probably never be another quite like it.
www.glaswerks.com
