Loading.....DC resistance?
Xander8280
Post by Xander8280 »
I have a cabinet setup in a hifi sort of way. 8ohm woofer in series with an 8ohm celestion driver. There is a nonpolarized 100uF cap between to high pass the celestion driver @200Hz roughly.
Using my 16ohm tap on my tube amp.....am I going to have a load mismatch?
The cap should be a DC block and for AC anything below 200Hz will "see" a high resistance...
Bad idea or acceptable?
Thanks for any help!!!!
Post by Stevem »
Use the 8 ohm tap on your amp.
The bad idea part is the big 12 Db dip in frequency responce you will have around that 200 hz point, flat your responce will not be to speak like Yoda!
Malcolm Irving
Re: Loading.....DC resistance?
Post by Malcolm Irving »
Maybe I have misunderstood, but if your two 8 ohm speakers are in series, then the cap must be in series too. That would block low frequencies for both speakers.
Malcolm Irving
I think the speaker circuits should be wired in parallel, like this:
Tip of jack socket to +ve terminal of 8 ohm woofer,
+ve terminal of woofer via series cap to +ve of tweeter,
-ve terminal of tweeter to –ve terminal of woofer,
-ve terminal of woofer to sleeve of jack socket.
At low frequencies you have the 8 ohm woofer more or less working alone.
At high frequencies you have the tweeter in parallel, but the speaker impedances are higher at high frequencies, so it’s still good to use the 8 ohm tap.
David Root
Post by David Root »
A simple 2-way crossover might work better.
When I was a boy I was told that anyone could become President. I`m beginning to believe it--Clarence Darrow
Xander8280
thanks guys.
Going to remove the capacitor all together. I may just add an L Pad or two with bleed caps. The main goal was to have a full range cabinet that can handle a lot of low end. Celestion g12's bark with the volume I may drive them in...I have tested my cabinets without highpassing and it has scared me. I hope they haven't creased, won't abuse them as much.
Once again, guitarist/bassist abusing drivers. lol
2016 will be great!
