Sounds really good I think.
Have you played it with a band, or gigged it?
How's volume level? Keep up with a firm handed drummer?
Love to hear the strat, single coils.
Thanks, nice work.
						New Deluxe 5E3 Tweddle Dee build
				Delmar Evans
Re: New Deluxe 5E3 Tweddle Dee build
Thanks!  I rehearsed with it for 3 hours, but did not put it through its paces. Will probably gig it over the holidays. It Ran flawless with no issues.  A really need to make a cabinet for it.  Cannot decide if I want it in a combo cab or not.  With that low end and volume ,  I find with my current 5E3 ,  I knock the inside of the Tubes loosen in V1 and V2. Also. It seems to keep up with our drummer , but he is not heavy handed. If I can get it together, I set up a couple of room Mics for rehearsal next week.
									Delmar
				Delmar Evans
For those Fender players, here is one more comparison using a Strat.
https://youtu.be/JhmGoZTDgks
Delmar
Yep, that's working!
Hey thanks Del, I appreciate the Strat walk-thru.
Sounds real good man,thank you.
				Delmar Evans
No problem. I think I was pushing the volume a little too hard on that. I know that if you're running the Volume between five and six instead of eight and nine, and put the microphone a little bit closer so it's not picking up so much room noise you get the full feel of the tone that the stratocaster has. I try to do these snippets using the Sennheiser mic because it is pretty neutral sounding.   Doing a recording just using the microphone on the iPhone is a disaster   Maybe I'll put together one going through my board with a little bit of reverb and lower volume so I can really control the gain.  I know that playing live your ears trick you a lot,   But that's really what you're hearing the amp can do.   I wish I had a telecaster I could try the only thing I have left is an ES 330 ! Thanks to all for the comments and thanks for watching
Delmar
Really digging that with the strat.  I might have to do some surgery on my 5E3
Good stuff. Thanks for sharing this!!!
				titser_marco
Now I want to build one for myself!
