Here is Samson:
Clip:
https://www.youtube.com/watch?v=JvJ2XzX_AdQ
Thanks, I haven't been around and I forgot..... Doh! I will use the search engine next time....Colossal wrote:Hi Carl,
Didn't you already post this one?
https://tubeamparchive.com/viewtopic.ph ... ht=express
Cool to see it again though. It sounded really good.
SilverFox wrote:Do you have a schematic of the changes? This Rocks! I really like your builds and videos.
Just looked at the original post and saw the TS is from Merlins Book. I think I like this better than the Naylor SD clones.
silverfox.
Someone is having too much fun!BTW, ignore the 65' JTM45 in the background...
Doh! Will correct. Also, I neglected to write the value of the PPIMV dual pot. 250K A. I used a PEC.pdf64 wrote:Thanks for the schematic. The power tube control and screen grids may need swapping around on it![]()
Because it is cathode biased, the pots are the 250K reference to ground. A typical cathode biased circuit has 220K's to ground. 250k is close enough.pdf64 wrote:What led you to choose to put the master pots 'backwards, 5e3 style?
FB,fusionbear wrote:Fifth, the cathodes of V3 are connected to a 75 ohm resistor.
