50 watt lead or JTM45
pdf64
Re: 50 watt lead or JTM45
Post by pdf64 »
The 784-139 OT can be mismatched to put a 6k8 load on the power tubes, which seems to work fine for KT66 or EL34.
Spunky99
Post by Spunky99 »
I had a JCM800 2203 that came with 6550 tubes and it was the bomb but too loud. The 784-139 OT can handle EL34, 6550, KT66 and KT88 tubes.
I'm trying to find schematics and a layout for a 67' 1986 Bass JMP.
I want the tube rectifier vs SS and add a master volume to the rear so I don't go deaf or have to use an attenuator.
pdf64
Post by pdf64 »
The issue as I see it is that 3k4 is a heavy load for the 25 watt tubes, unless the cranked VB+ is under ~400V.
Try plugging the numbers into http://bmamps.com/Tech_tds.html
Bear in mind to use the appropriate full load supply voltages, rather than static values.
