 Anyway, someone seriously fucked this thing, and I'm amazed anyone would be so incredibly thoughtless. Here are some pics of it right after it was dropped off... Mind you, I didn't remove the cap pan.
 Correct, the tuxedo Blonde Bassman's are a rarity too.katopan wrote:If the faceplate is black (it looks so in the pics) then the original tolex would've been black rather than blonde. One of the '64 transition "Tuxedo" models.
It's a good idea to use a light bulb limiter in these scenarios.I got the itch to try and play this thing with parts on hand and went through three fuses. After some snooping, I discovered this wire tied to the + of the reservoir caps.
