Fender Deluxe Reverb AB868 Squeal
pdf64
Re: Fender Deluxe Reverb AB868 Squeal
Post by pdf64 »
No, my strong suspicion is that the old cap has already effectively disconnected itself via a high ESR failure, ie it may as well not be there.
And as mentioned above, insufficient decoupling at a shared, cascaded cathodes opens a pathway for positive feedback; when the reverb control is increased sufficiently then free running oscillation may result.
Post by Stevem »
If you lift the feedback wire off of the speaker Jack does the issue get worse or better?
Does it look like the OT may have been replaced?
Just for kicks swap the brown and blue output tube plate wires, does this change the issue any?
BungleSim
Post by BungleSim »
pdf64 wrote:No, my strong suspicion is that the old cap has already effectively disconnected itself via a high ESR failure, ie it may as well not be there.
Replaced the V4 cathode cap and the squeal went away! The four other 25uF cathode caps were all dry so I replaced those and the amp is sounding good again. Thanks for everyone's help in not only fixing the amp but getting me to understand the whats and whys!
Post by Stevem »
Cool deal, glad to hear it!
pdf64
Post by pdf64 »
Yea, good result!
It nice to identify a faulty part before starting a campaign replacement.
