Pre-build that tone stack
gahult
Post by gahult »
Probably something that many have seen. But for new builders this is a lot better than fighting poor access in the chassis. Just screw em down, solder it up, pull it off and drop it in all done.
Gary
In the 60's people took acid to make the world weird. Now the world is weird , and they take Prozac to make it normal.
Re: Pre-build that tone stack
That's a good tip, Gary
sluckey
Post by sluckey »
I've done something similar on several builds. I mount the pots on the outside of the chassis, wire them up, then just flip the whole assembly to the inside of the chassis.
[img:950:712]http://home.comcast.net/~seluckey/amps/ ... nov_02.jpg[/img]
harleyboy2112
Post by harleyboy2112 »
I do the same thing with input jacks. Especially for 4 input amps. It works great!
JMFahey
Post by JMFahey »
Cool tip :idea:
