I'm getting parts together for a JTM45 build and am struggling to decide on the power transformer. I've already got a 6.6K OT and will be getting a 10H Choke but I can't decide on the HT Voltage.
I have found a transformer which gives a 345VAC Secondary but I think this will be a bit high. I imagine with that I'll probably get 460/470VDC after the valve rectifier? The other transformer I've found for the job in the UK is the Hammond 290LX which will give a 300VAC Secondary which means I'll end up with 390/400VDC after the rectifier. Only issue with that is I think it looks pants http://www.hammondmfg.com/jpeg/290LX_B.jpg
I mean its got to look good as well right
There is a third option and thats buying the transformer Marshall use in their JTM45 reissues, which I THINK is 300VAC secondary but I haven't got a clue what the current ratings will be. Plus I'll need to find a wiring diagram for it as it is supplied as a replacement part.
What do you guys think? Is there another supplier in Europe that I'm missing out?
