Any of you familiar with the Red Iron T-Rex? It is very TW Express like but with octal tubes and a "James" tone stack. I really like this amp! I have looked under the hood, but am hesitant to post any pics out of respect for the builder. The amp is easy to play , but never falls apart even when maxed out. It is also Cathode biased. This one has a Tone Stack bypass mod as well as a cross line MV which actually works quite well...
I listened to the sound clip/YouTube vid. Wow you weren't kidding, it really stays tight all the way through the volume spectrum. Seems like there's some kind of voodoo at work to get this level of performance out of a cathode biased amp. Any hints at what they've done w/the circuit to achieve this...without creating any enemies @ Red Iron? A cathode biased 6CA7 TW or is there more/less to it?
Choke input filter - bingo, that's the voodoo* I was looking for This is cool because it drops much more voltage from the PT's HV secondary than a cap input filter, and as such I'd imagine would allow the builder to use a bigger, more powerful PT with a high mA rating on its HV secondary without having too high B+ or running into a large expense of having custom transformers wound.
*voodoo = something not commonly found/used in guitar amp designs and therefore the knowledge and opinions of the characteristics of its implementation are limited, murky, mysterious, unknown...chicken bones!
shane wrote:Doesn't necessarily have to be a choke input filter. could be a Pi filter like the Allesandro.
One big difference is that the Allesandro's that have been on my bench fall apart as you crank them. They get too squishy and have ghosting that I don't care for.
I think the only catch w/a choke input filter is that the choke has to be rated to handle the full current pulled throughout the entire amp, whereas w/cap input filter circuits that have a choke feeding the screens the mA rating of the choke can be almost anything to taste. Am I thinking about this/seeing this correctly?
