And then there's this....
- FUCHSAUDIO
A mix of our Fuchs Clean Machine tone stack on channel one and the ODS (c) dirt channel on channel two with an overdrive tone control, two Fx loops, global master and accent control, our gain boost that works without bypassing tone stack, PLUS a tone stack bypass (for stupid amounts of gain). It allows the first channel to get into mild overdrive zone, while pushing channel two over the top....ODS-II....fan cooled aluminum chassis, built in bias test metering and external adjustments, 6-way footswitch standard. Second footswitch optional as is midi control. 50+100-W models coming, and pre-orders in place already....
						Re: And then there's this....
Well, I'm glad to see you're making progress on your simple, easy, "beginner" model amp, Andy. Nicely done.
				groovtubin
Andy, it just tickles me you have the time $$$ and foundation to do this, my best wishes for success, n it`s a SURE thing! Looks and sounds fantastic!FUCHSAUDIO wrote:A mix of our Fuchs Clean Machine tone stack on channel one and the ODS (c) dirt channel on channel two with an overdrive tone control, two Fx loops, global master and accent control, our gain boost that works without bypassing tone stack, PLUS a tone stack bypass (for stupid amounts of gain). It allows the first channel to get into mild overdrive zone, while pushing channel two over the top....ODS-II....fan cooled aluminum chassis, built in bias test metering and external adjustments, 6-way footswitch standard. Second footswitch optional as is midi control. 50+100-W models coming, and pre-orders in place already....
Warmest regards, jim@Omegaamps
Cool, a bias meter.
That is very niceCHIP wrote:Cool, a bias meter.
 Cool cab as well.
     Cool cab as well.Re: And then there's this....
Very nice! I love the wood finish.
How many preamp tubes in total?
Cheers
Cheers
- FUCHSAUDIO
Only 4 preamp tubes total. Clean, OD, Loop, PI.
						- FUCHSAUDIO
Not really into broadcasting what we're doing Jelle, but here's a taste.
						- JazzGuitarGimp
Great looking amp, Andy! I see you are not using solder masks on your pcb, is this a cost-reduction measure, or is there a functional reason for this?
- FUCHSAUDIO
The main board is a prototype, so no mask. The power supply board is our standard ODS board. Our production boards are all two sided, solder mask, silk screened etc. good eye !
Are you bypassing the lytics with plastic caps?  Nice. I like the way that sounds.
						- JazzGuitarGimp
LOL - 31 years of pcb layout will do that to a fella I s'pose!FUCHSAUDIO wrote:good eye !
The built-in bias metering was also implemented on the Weber AB200 bass amp https://tubeamparchive.com/viewtopic.ph ... c&start=51
									John 15:12-13
