76 JMP w/EL34's 100 watts. Plate volts = 462
On tubes 1, 2, and 4 I'm getting .037 mA of current. Tube 3 no current and no voltage.
I have swapped tubes, changed the 1 ohm cathode resistor, even changed the tube socket.
Can anybody help me out, I'm stumped. Thanks
cathode current on 3 tubes
Re: cathode current on 3 tubes
Is its screen grid resistor good?
Is its heater heating (tube getting hot)?
Vdc on terminals 3,4 and 5?
Screen resistor. Thank you
You're welcome, thanks for the close out report!
