Ampeg Gemini 1 capacitor canister
terryrocks
Post by terryrocks »
Just received my replacement components from fliptops. However, the new capacitor canister is missing a tab. Can anyone recommend where I should route the lead?
Re: Ampeg Gemini 1 capacitor canister
What are the values in the old can?
What are the values in the new can?
I attached a schematic. Is this the correct amp?
terryrocks
It is the correct schematic:
Old:
Semicircle - 60microF @450v
Square - 40microF @450v
Triangle - 10 microF @450v
20microF @25v
New:
Semicircle: 70mIcroF at 450v
Square - 40 mirco @450v
Triangle - 40 micro @450
Leo_Gnardo
Post by Leo_Gnardo »
terryrocks wrote:It is the correct schematic:
Old:
20microF @25v
New:
You will have to use a separate cap to replace the 20 uF @ 25V. No problem if it's over voltage say 50V, or nearly the same, as in 22 or 25 uF. Good idea to mount it somewhere it won't get toasted by the resistor it's bypassing or any other hot R's or tubes in there.
Post by Stevem »
Seing as these Amps are now powered by more line voltage than there parts where spec for and all the internal voltages are higher I would up the voltage rating of the cathode bypass cap to 35 volts .
