I'm lookimg for 6v6 PP amp schematics that uses 6.6k OT
Kagliostro
Post by Kagliostro »
I'm lookimg for 6v6 PP amp schematics that uses 6.6k OT primary impedances
K
JoeCon
Re: I'm lookimg for 6v6 PP amp schematics that uses 6.6k OT
Post by JoeCon »
http://mhuss.com/Plexi6V6/Plexi6V6c.gif
It's a 6v6 plexi and uses a 6.6k OT, from the picture.
Post by Stevem »
Why? The impedance of the OT does not make a impact on circuit design other than power supply voltage by enlarge!
Kagliostro
I've a problem with a build that has a pair of 6v6 on a 6.6k primary OT
and I'm thinking they are due to a low B+ (450v CT AC PT with EZ81 rectifier), the original project used 6aq5 and a 6x4 rectifier
and I would like to see circuit that are like as to give a look to the B+
voltage used in those circuits
K
pdf64
Post by pdf64 »
Post by Stevem »
Well a ez81 / 6ca4 is only rated for a first cap of 50uf, are you running larger?
Blackburn
Post by Blackburn »
Deluxe Reverb or a TW Express are the first two that come to mind.
Kagliostro
Thanks pdf64 & Stevem
The first cap is 33uF
the schematic is this, but was build with V1 = ef86 - PI = 12ay7 - power tubes 6v6 - rectifier ez81
[img:2082:1043]http://www.bensykora.com/7cylinder/7cylinder_final.gif[/img]
there were some changes also in component values and the realized amp is this
[img:3504:1638]http://i.imgur.com/1WM0JHB.jpg[/img]
PT and OT are the same of the original schematic
K
tubeswell
Post by tubeswell »
fixed bias 6V6s work good with a 6k6 Pr Z when the plates are running around 400 or more. They even can sound good with fixed bias at 380 or 390.
Littlewyan
Post by Littlewyan »
Trainwreck Express
gui_tarzan
Post by gui_tarzan »
Stevem wrote:Why? The impedance of the OT does not make a impact on circuit design other than power supply voltage by enlarge!
Wait, I thought the output tubes & OT had to be in the same impedance range for them to work correctly?
--Jim
Littlewyan
They do but the impedance you use also depends on what voltage you're running the valves at. So a 6V6 running at 250V requires a 10K OT but when running at 285V the valves require an 8K OT. But this is only for perfect matching, as its a guitar amp rules don't apply :D. If the voltage is between 300V and 400V then 6.6K will work fine for 6V6s.
pdf64
Post by pdf64 »
The plate impedance of the power tubes we use seems to be 5 to 10 times greater than the primary load impedance.
The max power transfer theory http://en.wikipedia.org/wiki/Maximum_po ... er_theorem doesn't seem to apply, perhaps due to plate impedance not behaving as a simple linear resistance.
gui_tarzan
I still think there is magic working in these devices. :)
--Jim
Post by Stevem »
Is that EZ81 gonna be pushed too hard with 350/350, I forget its limits, a 5y3 may be a better pick?
