Well after having two fairly successful builds (one kit and one scratch) under my belt, I find myself hopelessly addicted and feel the uncontrollable need to fire up my needle/soldering iron!
I keep reading regularly about the magic of the "Tweed Deluxe" and the only way I will ever be able to afford to experience that "magic" is to build one. I mean, even if I find one in some store, they certainly won't allow me to properly put it through it's paces and crank it up, etc!
I want it to be as close to authentic as possible to really see what all the hub-bub is about. Where to start?
Being a cranked up Marshall kinda guy, I'm not certain that this an amp I will want to keep and use regularly, so on one hand it seems logical to spend the $$$ to make it cosmetically appealing with an eye towards possible sale. IE: Tweed combo cab, authentic chassis/faceplates, etc.
On the other hand, I already have a fairly suitable chassis that could easily be used for either a head or combo style build (a head would likely be more useful for me) and sourcing a "small parts kit" and the transformers of my choosing could certainly save a few $$$, as well as not being locked into one or another vendor's idea of what is "close enough" to authenticity.
I do want to go with a turret board as opposed to eyelet construction, even though some folks have mentioned that the "Tweed Disease" sometimes cased by the slightly conductive, old style eyelet boards may be part of the magic!
I see a lot of back & forth discussion about the power transformer options, concerning going with the original higher voltage approach vs. the "lowered" 630v-0v-630v units. What were the actual voltages of the original and how do they relate to our current (pun intended) state of higher wall voltages in the range of 123VAC to 125VAC?
I really want this build to be truly representative of the supposed "glory" of plugging into a really good original unit.
Thanks Folks,
Gene
