This is for the second stage 100k plate and cathode 820r/25uf.
In the AB763 fender schematic there is B+ of 410 and plate voltage at the tube 270v and 2.1v at the cathode.
My amp stock: B+370v
Plate "r" 100k, 207v at the plate and 1.3v at the cathode.
Plate "r" 50k, 260v plate and cathode 1.6v.
The notes seem "snappier" with the 50k/higher plate voltage, while the notes are smoother with the 100k/lower plate voltage.
Would this be bad for the tube?
The solution is probably math
