Split plate load common cathode gain stage. The resistor going to B+ is 56K the resistor going to plate is 47K. Lets say the gain (A) of the stage is 100. The output comes from either the plate or the node connecting both resistors. The output feeds a 0.01uF cap with a 1M resistor to ground.
1. If we take the output from the plate the gain is 100.
If we take the output from the resistor joining node
the gain (A) = [47K/(47K+56K)]*100 = 45.6 Correct?
2. Lets say ra = 50K, this makes the output impedance
(Zout) = 50K*(47K+56K)/(47K+56K+50K) = 33.7K Correct?
3. Regardless of where the output is taken (node or plate) the output
impedance stays the same correct?
4. Calculating the frequency response for the plate output is simple f = 1/(2*pi*R*C) where R is 1M + Zout. f = 15.2 Hz. Is the cutoff frequency the same for the split node output? I would think it is but I want to confirm.
I am trying to wrap my head around designing a split load gain stage in case you were wondering
Thanks!
