VVR (cathode bias) suitable for preamp fixed bias amp
guile
Re: VVR (cathode bias) suitable for preamp fixed bias amp
Post by guile »
To be sure I attached a picture. Should I interrupt the lead there?
It's difficult to tell what you have there since it's a non-standard layout, and I don't want to guess. Do you have a schematic for this amp as-built?
guile
Post by guile »
martin manning wrote:It's difficult to tell what you have there since it's a non-standard layout, and I don't want to guess. Do you have a schematic for this amp as-built?
Hope this helps!
See attached. In either case I Think it would be a good idea to put a diode (1N4007) in front of the VVR input.
guile
Post by guile »
Again thanks Martin.
What would be the orientation of the diode?
Banded end (cathode) towards the VVR input.
guile
Post by guile »
martin manning wrote:I think you might want to try it both ways. Basically the difference will be PI distortion vs. effect on the negative feedback loop.
I'm interested to know what the difference in sound and feel there is between PI distortion and effect on the negative feedback loop. Could that be described in any way?
guile
Post by guile »
I did some testing and decided to go with only regulating the preamp. The difference is very noticeable not only in a warmer, fuller sound, but also in a more compressed feel and attack.
Great! Sometimes the best course of action is to just try it and see, especially if the experiment is an easy one.
guile
Post by guile »
It's hard to describe the amp now but I think 'juicy' about covers it XD
Downside is that I have scratshy pots and true bypass pedals pop when engaged. Is there anything that can be done?
Guitar pots or amp pots? Which ones?
guile
Post by guile »
Volume of amp, volume of guitar and pickup selector.
Only noticeable when voltage is regulated very low.
And very nasty pops in true bypass effects.
These are common issues with VVR at low voltage settings. You'll have to block DC (grid current) from the pots and the input as shown, and maintain the ground reference.
Last edited by martin manning on Sat Sep 27, 2014 3:47 pm, edited 2 times in total.
sluckey
Post by sluckey »
Why would you replace that 1M with a jumper? Doing so makes J1 useless.
Oops! Just take it out. Thanks for catching my mistake!
