Same for me...NKK switches. Very solid with a hard, loud snap when you toggle them. I've never had one failure and won't use anything of lesser quality. I'm not interested in saving money where handling and switching voltages are concerned.
Ken Moon wrote:I've been using the NKK switches for over 10 years with no failures, and I think the switching effort is "just right", once you mount it in an amp.
I recently tried a larger 250V-rated toggle that was so stiff, I could lift the combo amp off the ground by the power switch before it switched
Another thing I like about the NKKs is the large solder lugs, which come in handy when soldering pilot lights, etc.
Here are 2 NKKs in a simple 18W pcb amp, and they switch easily, but with a nice solid "click":
