New 28 terminal switch
- Reeltarded
Re: New 28 terminal switch
Choices. I'll take the poular two or three, thanks!!
The guitar player who needs this already annoys me to no end.
Only 6 positions?
http://www.stewmac.com/freeinfo/i-0072/ ... agrams.pdf
That'd be great stuffed inside an ES-335!
- Reeltarded
I thought he got the message. Do I drive faster or use a bigger car? Very confusing.mhartman wrote:The guitar player who needs this already annoys me to no end.
Gang it with 2 six position double pole switches for more possibilities than physically possible.Zippy wrote:Only 6 positions?
That'd be great stuffed inside an ES-335!![]()
Pass the tequila and the soldering iron - and don't get 'em mixed up!Reeltarded wrote:Gang it with 2 six position double pole switches for more possibilities than physically possible.
- randalp3000
Is this the switch used in the Jimmy Page LP custom reissue?
That's it, my next Steel String Singer build is going to have 28 position High and Low filters.
Hahaha, I was just going to suggest that these switches be used for the ultimate in High and Low Filter selectionmhartman wrote:That's it, my next Steel String Singer build is going to have 28 position High and Low filters.
Jeeze, I can barely cut it w/one pick up
- Reeltarded
You could use it! Series.. paraserial. serelleapara.. raeriesallel.. it's endless.
You could really make a mess with a 6 amp rig though. Discrete lines for each amp. 6 output jacks. All the pedals from that guy with all the pedals.. times six. Just the wallwarts would load down the regional grid.
Bzzzzghhhhhhhhht! snap snap! pow!
However you use it you're gonna have to add a digital display, how the heck is anyone ever going to know which of the 28 positions they're actually in
StewMac better get on it.
If you need more than two pickups and 3 positions to sound good then you need to looking into playing another Instrument period!!!
Whoa, no love for Strats?!Stevem wrote:If you need more than two pickups and 3 positions to sound good then you need to looking into playing another Instrument period!!!
What about Gibson ES-5?
I s'pose you've got some baggage with ES-345?
Tough crowd...
No, I am fine with a 5 way also, it's just at some point you gotta be able to just play!
