PT Snubber
C Moore
PT Snubber
Post by C Moore »
I guess "snubber" is the correct term.
The cap(s) you see across the PT secondary of many older amps.
Do they act like a phase inverter fizz cap.....causing phase cancellation above a certain frequency.?
Are they "necessary"...still used today.?
Thank You
http://www.prowessamplifiers.com/schema ... C_100.html
http://www.prowessamplifiers.com/schema ... /1986.html
Re: PT Snubber
Post by Stevem »
They help with the noise hash made from the diodes turning on and off, in latter Fender amps they put a .01 cap across each diode in the bridge.
If you build or change over to fast recovery type diodes you do not need them.
C Moore
Re: PT Snubber
Post by C Moore »
OH...OK.
Thanks.
Round numbers...if my DMM measures 700 VAC across the secondary.
Would I need a cap with a V rating of 700 x 1.4= 980V .?
(I guess that is why Marshall use 2x 630V cap in series.?)
Thank You
Cliff Schecht
Re: PT Snubber
Post by Cliff Schecht »
C Moore wrote:OH...OK.
Thanks.
Thank You
If you are measuring voltages that high with your multimeter, make double sure that the peak-to-peak voltage you are putting in is within your meters limits. I fried a high dollar Fluke (not mine thankfully) testing some unknown transformers and one of them was putting out nearly 1200V p-p. Poor Fluke never stood a chance :(.
Cliff Schecht - Circuit P.I.
Re: PT Snubber
Post by Stevem »
Yup, a 1000 volt cap.
C Moore
Re: PT Snubber
Post by C Moore »
Again...Thanks for the answers and the info.
I am sure it CAN very a lot, from one amp and power supply to another...but generally speaking...do you guys use this cap(s) across your PT secondary.?
Assuming "normal"...general purpose diodes...do you guys notice some switching noise without a cap.?
Thank You
