E-Waste
C Moore
E-Waste
Post by C Moore »
I was "gifted" a JBL Bass-20. Both speakers are blown bad. Even if new, I have no use foe anything like this. I measured the PT secondary, but I cannot remember what it was.....18 VAC, or something like that.?
Is there any use for this.? Even to strip something off of it, and use as a piece of test equipment.....or should I just e-waste the whole "kit and kaboodle".?
http://www.bytefixx.com/ebay/unh238.jpg
Re: E-Waste
Post by Stevem »
You could use its power supply as the bias supply for tube amp development rig, thats about all I could think of!
sluckey
Re: E-Waste
Post by sluckey »
That heatsink may be useful for building a bench dummy load?
C Moore
Re: E-Waste
Post by C Moore »
Those are some good ideas.
Regards the dummy load.....I guess look up the power-out spec of the amp, or the power transistors to get an idea of how much heat it can dissipate.?
sluckey
Re: E-Waste
Post by sluckey »
That's way too technical. Just open it up and see if there is enough flat surface area to mount some power resistors on it. Kinda like this...
C Moore
Re: E-Waste
Post by C Moore »
It is NOT too technical.....it IS too stupid. :)
You said "dummy load" and I got tunnel vision...thinking we were talking about resistance. I forgot we were just talking about a bare Heat Sink....... :oops:
eniam rognab
Re: E-Waste
Post by eniam rognab »
that PT probably can put out some serious current, you 'could' build a cool SS amp with it (run and hide emoticon) CT? if so you can generate a +/- supply with a bridge rectifier... just a thought
or build a benchtop variable voltage regulated DC supply with like a LM317, or build a sweet pedal board power supply, you could run a crazy rig off of that, like the Edge's pedal board
i dunno, just throwing idears out there, lemme know if you like anything, i could point you in some direction hopefully
kindly,
neal
C Moore
Re: E-Waste
Post by C Moore »
eniam rognab wrote:that PT probably can put out some serious current, you 'could' build a cool SS amp with it (run and hide emoticon) CT? if so you can generate a +/- supply with a bridge rectifier... just a thought
kindly,
neal
OK....."or build a bench-top variable voltage regulated DC supply with like a LM317"
THAT sounds like it could be a handy "thing" to have around. :)
eniam rognab
Re: E-Waste
cool! glad i could provide some help! definitely a handy item to have on hand :lol:
not all LM317 are created equal, and maybe you will have too high of an input voltage...
check out a TL783C from Texas Instruments. look at the datasheet for a sample schematic, these can handle way more volts than a 317.
also, notice in the datasheet at the top highlighted "samples" i got three for free! they want to put these in the hands of designers so bigger orders will be placed. all you need is a business license or a school email. plus they are very cheap anyway, i would go for the TL783C if i was you, i made one with GREAT results!! ive got a +35v to 1.25v regulated supply, very handy
have fun!
neal
edit: don't ewaste!! at least until you pull all the useful stuff out first :D
eniam rognab
Re: E-Waste
aww nuts, no 'samples' on the datasheet :oops: .... didnt mean to get your hopes up... still, they are probably like $2 or something probably less
datasheet page 9 for schematic, one of the simplest builds you will ever build probably! :lol: :lol:
