Tweedle Dee, Tweedle Dum in the making
CHIP
Post by CHIP »
My new board is ready, I pulled the board from my Tweed Deluxe clone. ( probably just get another chassis, PT and OT ect... someday and revitalize it).
I already had the 5E3 board which I never used to begin with. Drilled some additional holes , put in about 15 additional eyelets and went with it.
Thanks again Charley, your hand drawn layout was my main guide.
Thanks to all others for their contributions.
Just couldn't resist trying out this circuit.
vibratoking
Re: Tweedle Dee, Tweedle Dum in the making
Post by vibratoking »
Let me know your impression of the difference between the two if you would. I am thinking of doing the same thing, but I really like my 5E3.
CHIP
Post by CHIP »
vibratoking wrote:Let me know your impression of the difference between the two if you would. I am thinking of doing the same thing, but I really like my 5E3.
Will do vibratoking.
CHIP
Post by CHIP »
IMO, If you really like your your 5e3, you will like this amp even more.
I just finished mine up today. It really is an improvement from my original 5e3.
My voltages are coming in a little lower than Charley's
360 vdc on power tube plates
21 vdc on cathodes
about 173 vdc on both V1 plates.
V2 1 is 203vdc
V2 6 is 248vdc
My PT is putting out 322 vac with 121 vac on the primary.
Using JJ GZ34S, JJ 6V6's
Still sounds great even with only 360 on the plates. It's a 5e3 on steroids.
Zippy
Post by Zippy »
Thanks for the feedback on that, Chip.
What PT are you using?
CHIP
Post by CHIP »
I rechecked my voltages. I was plugged into a Furman regulator and my primary was actually 118VAC.
At 121 VAC I'm getting 360 VDC on the plates.
The PT is a Mercury Magnetics FTDP-350.
I think the JJ GZ34S may be funky, because I recall having 350 DVC on the plates of my original 5e3 with a RCA 5Y3 rectifier. :?
With 315VAC on my PT secondary, I should be getting @ 410 VDC unloaded from the rectifier.
The amp still sounds extremely good. Very happy :D
ToneMerc
Post by ToneMerc »
Looks great Chip!
TM
CHIP
Post by CHIP »
Thanks TM. I always admire your work and contributions.
This really is a fun amp to play. I'm really liking how it sounds with a Tele and Strat, I find I prefer the bright channel with them. Haven't spent much time with humbuckers yet.
I had the bright Vol on about 4 and the normal channel on about 10, Tone on 6, brings it right in on the edge of breakup up with lots of pleasing overtones.
The low end stays nice and tight.
I may try some Sylvania 6V6's soon.
This is gonna be a nice amp to grab and go for practice or gigs.
I'm using a Weber 12F125-O 30 Watt speaker.
67plexi
Post by 67plexi »
Chip that's great you could use the old board and new production parts to get a killer amp
Just wait until you record with it, you're in for a nice surprise. Now you know.
Steve.
:D
CHIP
Post by CHIP »
I don't understand why I'm getting 322VAC coming off of pin 4 and pin 6 of the GZ34 and only 360 VDC on my 6V6 plates. Shouldn't the DC voltage be approx.
322 VAC x 1.3 = 418VDC ?
Or is it 360VDC due to the loading at the first filter cap?
67plexi
Post by 67plexi »
Chip what is your voltage pin 8 on the GZ34 and pin 4 on the 6V6
voltage loaded.
I used a MOJO756EX 384-0-384 PT pin 8 GZ34 399 VDC
B+2 pin 4 6V6 360 VDC. under load. So if you have 360 VDC on pin 4
you got it.
Steve.
ToneMerc
Post by ToneMerc »
CHIP wrote:I don't understand why I'm getting 322VAC coming off of pin 4 and pin 6 of the GZ34 and only 360 VDC on my 6V6 plates. Shouldn't the DC voltage be approx.
I dont ever recall getting as high as 1.3 even with a Mullard or other vintage GZ34 in even a fixed bias amp. In this circuit, I don't think you are far off considering your PT is only around 319 @ 120V under load.
I set my PT up so that it should be no more than 370V or so with a GZ34.
TM
CHIP
Post by CHIP »
Steve,
At this time (due to fluctuating incoming house voltage) I'm getting 372 VDC at pin 8 on GZ34 and 340 VDC 0n pin 4 , 358DVC on Pin 3 of the 6V6"s.
I'm using a Merc Mag FTDP 350 PT, so I guess that's the reason I'm 30 volts lower than yours.
That's the PT I originally had in my 5E3.
I may look in to the Merc Mag 380 version.
CHIP
Post by CHIP »
TM,
Thanks,
I'm close to that right now, my preamp voltages are about right on.
The amp does sound great, so I may just let it be for now, enjoy it and play the crap out of it. :D
