@Smitty - sorry I don't what brand the resistors are. I just order 1w carbon film from the local electronics store. It must have taken me about 45mins for each switch. But was so proud when I finished them
@Electron - the gut shot won't be too far away. It's very similar to my Dumbleland. I used a 2k7 between the switches cause Sergio noticed a drop in volume with them and 67Plexi mentioned that SSS 5,6,7,8 used a 2k7.
@Martin - yes the resistor marked 270k. This is what was mentioned in Sergio's build thread.
Aaron
sergio wrote:I just completed my sss in #2 type circuit.
First impressions:
1)Great clean sound and a nice reverb. surely this is a totally different machine from an ODS. 2)For my taste the filter section takes away a bit of volume , need tweaks! ( I think to eliminate the 100k res in series to the coil).
3)with accent switch I can omitted the filter section ,so as to feel the difference.
4) I changed the Fet res. divider 220k/8.2k to 150K/9.1k because I had a low volume output.
Sergio
67plexi wrote:Sergio, Love the etched boards looks great. On your volume loss filter switches Replace the 270k resistor with a 2k7 or 2k2 that should do it. The resistor that connects the bass and treble switch. That was the value used on 5,6,7,8 150 watt SSS.
Looks like a fixed bias on the power tubes ???
Steve.
martin manning wrote:I think 270k should make the filter more effective. With the 2k7 you have much less resistance to ground at the output.
Did you leave the inductor out? I really can't see any use for it.
Hi Martin,
I just wired in an old TDK inductor, it had 582mH stamped on it. I'll try it with the inductor first and hear how it sounds.
I'll have another read through of the SSS thread with the LTSpice files again (for the 100th time), it's too small on the phone.
Aaron
It would be interesting to find out what the inductor sounds like in the circuit vs. shorted out. I ran some sims that show there will be a notch between 3-8 kHz when it's in, depending upon how the switches are set.
